vcGeometryFeature
vcGeometryFeature is the object type for Geometry features in a component.
Module: vcFeatures
Parent: vcFeature
AmbientOcclusionModevcAmbientOcclusionModeRWGets or sets if geometry supporting ambient occlusion is rendered in the 3D world.
CreaseAngleRealRWGets or sets an angle tolerance for smoothing surfaces based on camera angle and lighting calculations.
GeometryvcGeometryContainerRGets the container of feature's geometry.
OnDemandLoadBooleanRWGets or sets if geometry of feature is loaded when the feature is being used or enabled in its node.
PickableBooleanRWGets or sets the ability to select geometry of feature in the 3D world.
ShowBackfacesBooleanRWGets or sets if the back side of the geometry should be rendered in the feature. (Geometry that is not facing the camera in the 3D world)
ShowContentBooleanRWGets or sets the visibility of feature.
UriStringRWGets or sets the URI of source file for geometry used in feature.
